1989 Vauxhall Tigra OVERHEATING
1989 VAUXHALL TIGRA
BRIAN MULLINS
1998Vauxhall Tigra 4 cyl Two Wheel Drive Manual 90.000 miles
I HAVE REPLACED THE STATS ON THE SIDE OF THE RAD.I HAVE REPLASED THE THERMOSTAT IN THE PIPE AT THE TOP OF THE ENGINE.THE 1 WHERE YOU CAN TEST BY PUTTING IN HOT WATER.
HALF OF THE RAD ONLY GETS HOT.EVEN IN THIS COLD WEATHER IF YOU DRIVE ABOUT 5 MILES THE TEMP GAUGE IN CAR GOES OFF THE SCALE PAST THE RED.BUT NOT LOOSING WATER.I AM SORRY BUT I AM UNEMPLOYED AND WOULD LOVE TO DONATE AS THIS PROBLEM IS DOING MY HEAD IN.
Jan 16, 2010 at 10:43 AM
BRIAN MULLINS
[quote:e02f00613c="brian mullins"]1989 Vauxhall Tigra 4 cyl Two Wheel Drive Manual 90.000 miles
HALF OF THE RAD ONLY GETS HOT.EVEN IN THIS COLD WEATHER IF YOU DRIVE ABOUT 5 MILES THE TEMP GAUGE IN CAR GOES OFF THE SCALE PAST THE RED.BUT NOT LOOSING WATER.I AM SORRY BUT I AM UNEMPLOYED AND WOULD LOVE TO DONATE AS THIS PROBLEM IS DOING MY HEAD IN.[/quote:e02f00613c]FAN IS COMMING ON
Jan 16, 2010 at 11:44 AM
DAVE H
  • 13,384 POSTS
Start by flushing out the cooling system .. it may have a blockage somewhere ... also this may be due to a faulty water pump !
Jan 17, 2010 at 2:46 AM
