engine light
VAUXHALL
DANT2679
i have a vauxhaull corsa merit r reg it has 45000 miles on the clock and the engine light has started to flicker on and off,what could be causing this and could anyone tell me how to fix the problem... thanx :lol:
Aug 31, 2006 at 2:46 AM
MASTERVIPERUK
  • 4 POSTS
when the engine managment light diplays this means that there is a electrical or an electronic fault occuring on the on - board electrical system. To find out what the fault is, this is done through a diagnostic machine. Once this machine is attached to the vechile ECU it will communicate and display some sort of trouble code on the screen of the diagnostic machine, with the trouble code in hand, the component that has failed can be identifed. The above actions can be undertaken by your loacl dealership.
Oct 19, 2006 at 6:51 AM
