2002 Vauxhall Omega engine misfiring
2002 VAUXHALL OMEGA
DAVIDMG
Engine Mechanical problem
2002 Vauxhall Omega 4 cyl 80000 miles
Hi there, I am considering purchasing a 2002 Vauxhall Omega 2.2 CDX off a motor trader in Hampshire.
The seller has stated that the engine is currently misfiring.
Although he has taken this into account with his asking price, I am obviously a little concerned.
Apart from the misfire, the car is described as being in excellent condition inside and out.
Seller has invited any inspections on the car at their premises, and states they have a ramp which can be used if required for a more in depth inspection.
Any advice or general comments about the misfire are very much appreciated.
Thanks for your time.
David.
Jul 13, 2009 at 1:11 PM
Engine misfiring can be caused by worn or fouled spark plugs, a weak spark (weak coil, bad spark plug wire), loss of compression, vacuum leaks, anything that causes an unusually lean fuel mixture (lean misfire), an EGR valve that is stuck open, dirty fuel injectors, low fuel pressure, or even bad fuel
Jul 13, 2009 at 1:16 PM
