Engine Cooling problem
1998 Vauxhall Omega Two Wheel Drive Manual 130000 miles
Dear 2 Car Pros
I would like some advice about an S Reg 2.5 litre Vauxhall Omega Estate.
The water pump needs replacing as does the drive belt.
I have removed the Carb Air Intake hoses so as I can see the area clearly.
However, the pump is halfway out of its housing and I am unsure of how I can remove it safely.
You're advice would be crucial.
Thanks
Mike Davies - A new member.
Dear 2 Car Pros
Thanks
Mar 4, 2010 at 10:53 AM
