2005 Vauxhall Meriva oil filter
2005 VAUXHALL MERIVA
41,000 MILES • 4 CYL • 2WD • MANUAL
WINKS121
need to change my oil filter but can not find where it is to change its a 1.7 turbo diesel on a vauxhall meriva 05 plate anyone help??
May 26, 2009 at 9:40 AM
DAVE H
  • 13,384 POSTS
The oil filter is located on the engine block inside a plastic housing with a bolt down the centre for removing the inner element.. it is a new element type filter you just replace the element inside the housing .. not the whole filter as with the old type metal ones ... your local library or autoparts store will be able to supply a repair manual with instruction's and diagrams ... hope this helps
https://www.2carpros.com/forum/automotive_pictures/266999_AAA2_738.png
May 27, 2009 at 3:37 AM
