2004 Vauxhall Meriva steering column
2004 VAUXHALL MERIVA
70,000 MILES • 4 CYL • 2WD • MANUAL
JOJORAVEN
Vauxahall want to charge me 750 quid to renew my steering column following problems with my eps.
I would like to know if i employ an Auto Electrician would they be able to replace the torque sensor on the column.Apparently this is a common problem with these cars and the simple thing is to replace the sensor and set it up diagnostically.thanks
Aug 28, 2009 at 12:05 AM
DAVE H
  • 13,384 POSTS
you could have an electrician replace thge sensor .. setting it up correctly is a different matter .. a replacement unit would be advisable .. ask a non dealer garage to replace the unit !!
Aug 30, 2009 at 6:52 AM
