1993 Vauxhall Fronterra Front Brake Bleeding Screws
1993 VAUXHALL FRONTERRA
180,000 MILES • 4 CYL • 4WD • MANUAL
CULDAER
After changing the pads front and back I have found that I am going to need to remove the nipples from the front calipers and replace as they are unusable and I cannot bleed the brakes. Can you tell me the safest way to remove them without damaging the calipers as they are rusted in.
Thank you
Jun 9, 2009 at 3:58 AM
MHPAUTOS
  • 31,937 POSTS
Hi there,
Start with giving them a good spray with a penetrating spray or a freeze and release spray, try and work the bleeder back and forth till it starts to move, you may have to carefully drill the center and use a high quality stud extractor, don't use a screw in type as this only expands the bleeder, a knock in type is preferable.
mark (mhpautos)
Jun 9, 2009 at 5:09 AM
