1992 Vauxhall Fronterra fuel tank
1992 VAUXHALL FRONTERRA
ARCANE3
Engine Mechanical problem
1992 Vauxhall Fronterra Four Wheel Drive Manual
How do u drain the fuel tank, is there a release value,
Is there a gauge fitted in the petropl tank to stop you phyining the fuel out
Sep 10, 2009 at 3:51 PM
DAVE H
  • 13,384 POSTS
there is no drain or check valve to prevent syphoning .. remove the fuel supply line (tank to motor) and place the end in a suitable container .. and supply a power source to the pump !! or add your own pump to the line !!
Sep 12, 2009 at 5:07 AM
