2004 Vauxhall Corsa Engine problems
2004 VAUXHALL CORSA
LAURAONUOHA
Engine Mechanical problem
2004 Vauxhall Corsa Two Wheel Drive Manual 24000 miles
Firstly oil light went on, and ont he way to work the engine kept cutting out and the battery and eps light kept coming on whenever the engine cut out (It would stall whenever i stopped at traffic lights etc) I then got to work and let the engine cool down as it was a hot day, then i put oil in it. It was fine to driving home but then about 10 minutes into the journey the engine felt like it was going to stall and it cut out a few times and would not go anywhere unless it was in 1st or 2nd gear. Also, lots of white smoke was coming out of the exhaust which smelt like burning oil.
Please help!
Apr 9, 2009 at 4:32 AM
MHPAUTOS
  • 31,937 POSTS
Hi there,
Best you check your coolant level as whit smoke is an indication of coolant in the combustion this could be a head gasket or cracked head, also run a scan and check for set fault codes report back any findings her for more assistance.
Mark (mhpautos)
Apr 9, 2009 at 4:48 AM
LAURAONUOHA
Hi there, thanks for your quick response.
I was just wondering whether this problem would cause the engine to cut out aswell when I come to a complete stop?
Thanks
Apr 9, 2009 at 5:00 AM
MHPAUTOS
  • 31,937 POSTS
Hi there,
this will depend on the severity of the problem, normally a head gasket problem will induce a rough idle, if two cylinders are involved the engine would be more inclined to stall at idle speed.
mark (mhpautos)
Apr 9, 2009 at 5:53 AM
