2003 Vauxhall Corsa
2003 VAUXHALL CORSA
ZKHONAT
Engine Cooling problem
2003 Vauxhall Corsa 85000 miles
The engine management light came on and it has problems starting. I checked the fault code and it turned out to be the Engine Coolant temperature sensor. Anybody know where the sensor is located on a Vauxhall corsa 2003 1.2? Also this may be due to loose wiring because the car was recently involved in a minor "bump"
Dec 26, 2009 at 6:21 PM
DAVE H
  • 13,384 POSTS
check the wiring is connected to the sensor ! the sensor is located on the cylinder head close to the thermostat .. yuor local autoparts store will be able to supply a repair manual with instructions and diagrams
Dec 27, 2009 at 7:17 AM
