Electrical problem
2000 Vauxhall Corsa Two Wheel Drive Manual 54000 miles
Hi Car Repair I was hoping you could help me, my vreg 1.0 corsa has been running funny for a while now, loosing power mid acceleration and hunting when pulling away. I had the spark plugs replaced a couple of months ago with no change. The engine light has now started to stay on and the battery has completely died with no response after turning the ignition. I've taken the battery out the car to try and charge it up, is this ok? What could be causing the problem? Was going to get it put on the diagnostic machine when the battery died so I need to try sort that first. The cost of repair is looming in my mind, but I really want it running again as its a good car usually. Hope you can help me , Thanks.
Apr 4, 2009 at 12:06 PM
