1999 Vauxhall Corsa Timing Chain / Belt
1999 VAUXHALL CORSA
65,000 MILES • 4 CYL • 2WD • MANUAL
RHYSJONES350
My friend has a roughly 10 year old corsa and recently after a trip from Middlesborough to Manchester the car ran out of oil, presumably due to a leak somewhere, when we turned it back on after the journey home (which was fine all the way) the engine was banging like something was inside it.. After a bit of research we came to the conclusion that it's probably the timing belt being worn or corroded but my question is whether it is a chain or belt? I've looked online and can't get a straight answer anywhere, it's the ecotec engine and it's a 1.2. I have also heard that's there's a specific Vauxhall tool for replacing the belt, is it possible to replace it without using this tool? Other than the big-end bearing, is there anything else which could be wrong with it? There was 3 quarters of a full tank of oil before we set off, we didn't check it before the return journey but there were no problems then, only after the car had had 15 minutes or so to settle down. Thanks a lot.
Jul 28, 2009 at 11:37 AM
DAVE H
  • 13,384 POSTS
The 4 cylinder corsa has a timing belt ... remove the top plastic cover (left hand side of engine) to check the belt condition check the teeth as well..If the engine is still running, I doubt it is the timing belt unless a piece of the belt is stripped off and banging around ? if the belt broke it would bend valves and the engine would not start !! I suspect you have internal damage due to lack of oil ... probably the bearings as you suspect !! hope this helps
https://www.2carpros.com/forum/automotive_pictures/266999_AAA2_895.png
Jul 29, 2009 at 5:35 AM
