1999 Vauxhall Corsa Headlights
1999 VAUXHALL CORSA
109,000 MILES • 4 CYL • FWD • MANUAL
KAYLEIGHC
When the headlights are switched on, the blue main beam light on the dash board is always on dimly. After about a week of this the light came on at full brightness all the time and only the sidelights would show when the switch was in headlight position and had no main beam. Changed the main beam arm, checked the fuse, relays and bulbs and changed the connections behind the lights because the plastic connector on each had completely melted. They worked lovely for a couple of days but now the same thing has happened again. This time checked the earth wire no change, ran out of ideas!
Feb 28, 2008 at 4:04 PM
DAVE H
  • 13,384 POSTS
there has to be a short in the wiring somewhere !
Feb 22, 2009 at 9:19 PM
