1998 Vauxhall Corsa rear lights
1998 VAUXHALL CORSA
ANGELSCRY
Electrical problem
1998 Vauxhall Corsa Two Wheel Drive Manual 67000 miles
the brake and reverse lights worked until the icv was clean due to a build up of grease had stoppped it workin properly it was after this that they stopped apart from minor maintaince for mot no other work was done all the usual stuff as been checked bulbs & fuses the pedal switch was also checked used a circuit tester to make sure there was power to the fuse someone said an earth might be lose but as there are so many brown earths i have no idea where it can be any help would be much welcome as mot is on monday
Nov 6, 2008 at 1:31 PM
DAVE H
  • 13,384 POSTS
Check there is power going to the bulb holders ? (centre prong is live, outer metal is earth) if there is then earth out the metal plate which holds the bulbs to the chassis of the car .. this should let the lights work corrctly ..
Nov 7, 2008 at 9:44 AM
OPEL PARTS GREECE
  • 131 POSTS
Check the rear ground cable
Nov 24, 2008 at 1:11 PM
