1997 Vauxhall Corsa cuts out when hot
1997 VAUXHALL CORSA
HELENLB
Engine Mechanical problem
1997 Vauxhall Corsa Front Wheel Drive Manual
my car cuts out when it gets hot, ive had diognostic test and it said i needed new egr valve, ive had that changed and the car still cuts out when hot. do you no any thing else it could be cus dont want to have another test when they were wrong last time
Jul 22, 2008 at 11:41 AM
DAVE H
  • 13,384 POSTS
a common fault on the corsa is the coils breaking down when hot ?? try replacing these .. another common fault is the camshaft sensor .. both of these faults would give the symptoms you describe .. i personally would go for cam sensor first .. seen this hundreds of times in my previous life as an RAC roadside tech
Nov 7, 2008 at 12:16 PM
