1995 Vauxhall Corsa i have no idear
1995 VAUXHALL CORSA
CHEEKYDAVE2002
Noises problem
1995 Vauxhall Corsa 4 cyl Front Wheel Drive Manual 78'000 miles
there is a hissing noise coming from the cam belt all air pipe are ok. it hisses when idle and more when driving accelarating pick up is good not sure if it is the cam on the way out or water pump, not long sice rocket cover was replaced.
Mar 3, 2010 at 8:11 AM
DAVE H
  • 13,384 POSTS
check/replace cambelt,tensioner and water pump .. the belt is overdue replacement if it has not already been changed .. i would advise replacing the pump at the same time !
Mar 8, 2010 at 4:07 AM
