Water in the oil
2003 VAUXHALL ASTRA
KAOTIC55
4 cyl Front Wheel Drive Manual 44000 miles
I have noticed 'mayo' on my oil dipstick. Also under the filler cap.
I know the filler cap can get condensation. I usually do short journeys too and from work.
But i'm panicking that the 'mayo' on the dipstick means the head gasket has gone???????
Is this a definite indication that the head gasket has gone?
Engine is 2.2 16v.
Thank you. Andrea
Jan 27, 2009 at 3:17 AM
MHPAUTOS
  • 31,937 POSTS
Hi there,
If the oil is emulsified there is some quantity of coolant entering the sump, usually this will be a head or head gasket issue, are you using coolant? is there any misfire or white smoke? get a cooling system check done, and have the system checked for exhaust gasses in the cooling system, this is a simple chemical test that is conclusive for head gasket problems, start here.
mark (mhpautos)
Jan 27, 2009 at 3:51 AM
