1999 Vauxhall Astra losing water
1999 VAUXHALL ASTRA
97,000 MILES • 6 CYL • 2WD • MANUAL
PARKER8182
I am losing loads of water. There are no obvious signs of leakage, no patches of water under the car and the pipes are secured. We had the cambelt and water pump replaced and still the same. The oil and the water aren't mixing so it can't be the gasket. Has the pump been replaced correct? What do you suggest? Thanks for your time.
Oct 23, 2009 at 12:14 PM
DAVE H
  • 13,384 POSTS
I would have a cylinder compression test carried out .. the headgasket is a common fault on this vehicle ... is the car smoking white while running ? running rough ? overheating ?
Oct 25, 2009 at 4:09 AM
PARKER8182
The car runs fine.......No white smoke while it's running.
I put some radweld in it and it stopped losing water. But the car heats up to about 90 when in really slow moving traffic.......Is this a problem????
THANKS FOR YOUR TIME!
Oct 27, 2009 at 3:53 PM
DAVE H
  • 13,384 POSTS
90 is ok as long as the fans are starting to cool it down !!
Nov 2, 2009 at 4:23 AM
