1998 Vauxhall Astra wipers
1998 VAUXHALL ASTRA
162,000 MILES • 4 CYL • 2WD • MANUAL
AIDANQUIGLEY4
hi
i am having a problem with the wipers on my car. its the 98 to 04 astra.
the problem is that the wipers dont work at all on intermediate or when i squirt the washers but work fine on normal and fast settings. i have tried the motor,relay and switch from a car that was working fine but it is still the same for my own car i was wondering if there was a secondary relay or is it to do with the timing module? im not sure where to go with this because vauxhall dealer tells me it has to be the motor. if possible could i get a copy of a wire diagram to try and figure this out. any help would be much appreciated
Apr 19, 2009 at 5:46 PM
DAVE H
  • 13,384 POSTS
We do not have a wiring diagram for this vehicle as it was not released in the USA .. your local library or autoparts store will be able to supply a repair manual for the vehicle ..
https://www.2carpros.com/forum/automotive_pictures/266999_AAA2_542.png
Apr 20, 2009 at 6:05 AM
