1998 Vauxhall Astra white/blue smoke.
1998 VAUXHALL ASTRA
KRISTIANLLOYD
Engine problem
1998 Vauxhall Astra 4 cyl Front Wheel Drive Manual 130.00 miles
the cambelt on my astra broke & so bending some valves. valves were changed but not all now when the car idles white/blue smoke comes out when car is driven at 30/40 or 50 mph no smoke comes out when you rev a lot of smoke comes out. thanks for your time on this matter
Jan 3, 2008 at 9:51 AM
MHPAUTOS
  • 31,937 POSTS
Hi there,
If this was not a problem before the broken timing belt, you still have issues with the cylinder head. if they have just replaced valves, they may have missed cracked guides or damaged valve stem seals when installing. Check coolant levels as white smoke could be burning coolant. I would raise my concerns with the mechanic the did the repair.
Mark (mhpautos)
Jan 12, 2008 at 7:15 AM
