1998 Vauxhall Astra slight misfire
1998 VAUXHALL ASTRA
56,734 MILES • V8 • 2WD • AUTOMATIC
NOSHA64
hi when i start my car up there is a slight misfire and my rev counter goes up and down as the car gets hotter the misfire gets worse no problems when the car is going been to the vauxhall dealers they put it on the machine but the ecu wouldnt let the computer in an older machine found a fault it was the timing but i thought you couldnt set the timing on these please help as ive spent a fortune on the car
Aug 13, 2009 at 1:16 PM
Engine misfiring can be caused by worn or fouled spark plugs, a weak spark (weak coil, bad spark plug wire), loss of compression, vacuum leaks, anything that causes an unusually lean fuel mixture (lean misfire), an EGR valve that is stuck open, dirty fuel injectors, low fuel pressure, or even bad fuel.
Aug 13, 2009 at 3:38 PM
