Okay, does your key turn the ignition? It just doesn't turn off the security light so it will start? Or is that not the issue? What does it do if you put the key in and turn or try to turn it?
If you put the key in and turn it to start but the security light comes on, there is a failed component in the VATS system. Which is fairly common with that design. The sensor inside the column likes to fail. Then it doesn't send the signal to the BCM, and the VATS system locks the injection system so the vehicle doesn't run.
So please explain what it does when you try the key, thank you.
Apr 29, 2024 at 6:31 AM
