vapor canister
2013 FORD MUSTANG
93,000 MILES • 3.7L • 6 CYL • RWD • AUTOMATIC
BILL BOWEN
I have a V 6 engine. the engine light is on say something about the vapor canister. when i shut off the car you can hear it ticking around the rear of the car by the gas tank and when you fill up the tank it acts like it does not want to run. I wanted to know if it is the canister or the vent sol connector or the vapor canister purge solenoid?
Apr 7, 2017 at 10:13 AM
Hello Bill,
Can you run the codes and give me the code number please?
Here is a guide to help you
Please run this test and get back to us so we can continue helping you.
Best, Ken
Apr 9, 2017 at 2:54 PM
BILL BOWEN
Sorry I got your email but I have been working I go to work at 5 in the morning and get home between 7 and 7:30 at night so went by auto zone and got the codes the vapor canister code is gone but have these 4 codes 1} P2196 2} P0456 very small leak 3}P2198 4} P0456 very small leak auto zone recommends replacing the purge control valve
Apr 13, 2017 at 8:43 PM
Hello Bill,
Yep this sounds correct, also check all vacuum and vapor lines to make sure they are not failing apart.
Best, Ken
Apr 15, 2017 at 11:56 AM
