Vansudden stop pulling on hiway.now won't move.
2000 CHEVROLET ASTRO
180,000 MILES • 3.1L • 6 CYL • 2WD • AUTOMATIC
JEFFER10
  • 5 POSTS
Won't move....alternator not charging engine ovrrheated..transmission will not engage go in park no problem just revs and no go...
Feb 10, 2022 at 4:11 PM
You indicated an overheating issue, charging issue, and transmission issue. Have you confirmed the battery is fully charged? These vehicles rely on specific power voltages to function properly. A very weak battery can cause all kinds of issues.
Also, have you checked for diagnostic trouble codes? If not, I would start with that. Here is a quick video showing how it's done:
I realize not everyone owns a scanner, but often times a parts store will lend one to you. Let me know if you have already had this done and if codes were retrieved.
I will watch for your reply.
Feb 13, 2022 at 8:45 PM
JEFFER10
  • 5 POSTS
I'll put battery charge on start it up. Leaving charger on should operate electric systems. Then I put in gear and see what happens. I will let you know. thanks.
Feb 13, 2022 at 8:56 PM
Sounds like a plan. Let me know the results.
Feb 14, 2022 at 1:28 PM
