Had this vehicle for some time, but never used it. Installed new battery and tried to start it. First four to five times the starter solenoid clicked but did not turn over, then it did. seemed like it was starting (very rough as expected from lack of use), shut off and from then on, it would just click but nothing. Replaced solenoid next to battery, reconnected cables to original positions on solenoid, reinstalled battery (positive cable first), turned the key, got one click and then nothing from then on.
Disconnected negative battery cable and pulled, tested and cleaned blades of all the fuses in the power dist box, as well as tested all the fuses under the dash.
As most of my experience is with Dodges, any suggestions would be appreciated. Also, any ideas on locating a shop manual and electrical wiring diagram online?
Oct 1, 2017 at 12:51 PM
