speedometer does not work
1998 DODGE CARAVAN
2,444 MILES • 3.3L • V6 • 2WD • AUTOMATIC
LEFTY8
Only drives in second gear. it shuts off when coming up to a stop and speedometer doesn't work.
Jan 2, 2020 at 8:59 PM
Let's start with getting codes because I suspect that will tell us what the issue is. The reason is this could be a speed sensor or more complicated so we need to see if the vehicle is telling us what it sees as the issue.
Let me know what codes are there and we can go from there. Thanks
Jan 3, 2020 at 3:43 PM
Here is a guide to help you get the codes:
Jan 3, 2020 at 6:22 PM
LEFTY8
I haven't gotten the codes yet. I'm working on that. but I did change both sensors and still nothing..thank you for your help.
Feb 17, 2020 at 2:31 PM
Lets check on fuses. it sounds like the cluster when out if the fuses are good. here is a guide and the fuse locations in the diagrams below:
Check out the diagrams (below). Please let us know what you find.
Feb 18, 2020 at 11:12 AM
