Engine sometimes will not start?
1989 MAZDA B2000
420,000 MILES • 2.2L • 4 CYL • 2WD • MANUAL
RIKIKEES
Hi there,
I have a Mazda e2000 camper van. I have had problems starting sometimes it will start and sometimes it will not especially in winter time. Sounds like it has got plenty of battery to kick it over definitely smells like there is fuel in the carburetor. I changed the distributor to an electronic distributor thinking that might change. It will tow start real easy but sometimes will not jump start. When it is warm it starts straight away every time.
Oct 13, 2018 at 8:43 PM
So the engine will not crank over (starter not working) or it will not run? Here is a guide that can help:
Oct 15, 2018 at 5:28 PM
JOHN LOBEGEIGER
Your ignition coil has moisture from the rain so it's emitting a weaker spark.. get a hot air blow dryer or small fan heater and warm up the coil and dizzy.... it will start straight away.
Jul 28, 2020 at 3:46 PM
DEREKSR
Truck was idling and just died. I put a new coil, cap and rotor button, still won't start. I checked the fire from the coil, no spark. I looked at the fuses under the hood, 2 30 amp and 1 80 amp, they seem okay. Any suggestions what it might be?
Jul 29, 2020 at 12:32 PM (Merged)
JOHNNYT73
  • 924 POSTS
Check to see if you are getting injector pulse when cranking, along with the no spark. If your not getting either then I would suspect a crank position sensor.
MDJ423
Engine turns over but will not crank, has compression on all four cylinders, timing chain is good, battery is good, has fuel issues but still will not start even when spraying ether. The original problem was bad water pump but not will not start. Thanks for the help.
FIXITMR
  • 9,990 POSTS
you didn't say you checked spark?
CADIEMAN
  • 3,544 POSTS
check the injecter fuse also
