Van shutting down when driving
2003 GMC SAVANA
150,000 MILES • AUTOMATIC
DENISEJWELLS
When I am driving down the road the van will just shut off. I am wondering if it could be the steering column or what? I use the truck for work and I need to get it fixed ASAP. Any thoughts on what it could be?
Feb 4, 2021 at 8:21 AM
SEVAG P
  • 405 POSTS
hello,
Many thing that can make stalling when driving, to narrow down as a first step we must read the fault codes.
check our link below how to read fault codes
Check our link below how to fix stalling when driving.
https://www.2carpros.com/articles/engine-stalls
Read the fault codes and send to us for proper diagnosis.
thank you.
Feb 4, 2021 at 8:40 AM
DENISEJWELLS
There aren't any fault codes and no check engine light.
Feb 4, 2021 at 8:42 AM
SEVAG P
  • 405 POSTS
hello,
When the engine stalls it starts immediately or must be cooldown to turn on again?
Feb 4, 2021 at 10:41 AM
DENISEJWELLS
Starts immediately. I think it may be due to the ignition.
Feb 4, 2021 at 10:47 AM
SEVAG P
  • 405 POSTS
hello,
Yes it can be related to ignition switch but instrument cluster lights turns off also, if this happening check the ignition switch connector for loose wire, vehicle stationary engine running try to shake the ignition switch and its wires. if problem occurs then we narrow down the issue between ignition switch and the wires.
Please send us more information about the GMC Savana what type (1 ton, 1/2 ton or 3/4 ton)and the engine size, to send you the procedure with diagrams how to remove and reinstall ignition switch.
let us know what happens with you.
thank you.
Feb 4, 2021 at 11:23 AM
