Van misfiring after warmed up
1997 NISSAN QUEST
150,000 MILES • 3.3L • 6 CYL • FWD • AUTOMATIC
DADDYMIKAL90
  • 4 POSTS
My van likes to misfire only after its warmed up. Doesnt have a problem starting. Check engine light is on. have changed spark plug wires, spark plugs, ignition coil, fuel filter, air filter and krankshaft sensor. Still misfiring.
Jan 30, 2016 at 2:57 PM
WRENCHTECH
  • 20,761 POSTS
What are the codes numbers being set?
Jan 30, 2016 at 4:42 PM
DADDYMIKAL90
  • 4 POSTS
When I put it on a tester, it reads codes for knock sensor and maf sensor. Last week the crankshaft sensor read bad. Changed it and still just as bad at misfiring. Took my maf sensor out. It's practically bran new with no signs of damage
Jan 30, 2016 at 6:40 PM
WRENCHTECH
  • 20,761 POSTS
I need the code numbers not a description. What codes are resetting now?
Jan 30, 2016 at 6:44 PM
DADDYMIKAL90
  • 4 POSTS
I took it to O'Reillys to get the rest. I don't have specific numbers. Just know that it's show up maf sensor and knock sensor. I had two separate codes for the maf sensor
Jan 30, 2016 at 7:09 PM
WRENCHTECH
  • 20,761 POSTS
We need to know what is going on with the car now so the codes needs to be cleared and then the car driven until it sets the codes again and then get the numbers.
Jan 30, 2016 at 7:16 PM
