Shouldn't be needed. Those are screw in studs so unless they are loose that isn't the problem. While you have the covers off you might want to run through the valve clearance setting. As you have a "bad" set of valve covers you can make an oil catcher out of one. You basically cut the top of the cover out over each rocker arm so you can reach the rocker pivot nut and adjust them. The cover helps catch the oil that will spray around while the engine is running. As you are getting new valve covers I would wait until you have them in hand. You can also use oil deflector clips, but the oil then tends to overload the oil returns and runs down the heads onto the exhaust.
Adjusting hydraulic lifters with the engine running isn't that hard, just messy.
Start the engine and allow it to warm up.
Turn off the engine
Remove one valve cover and install your deflector clips, custom valve cover to keep the oil splash to a minimum.
Start the engine back up.
Begin to loosen one of the rocker arm adjusting nuts until you hear the valve-train just start to "clatter".
Slowly tighten the rocker nut back down just until the louder "clatter" just stops.
Turn the wrench an additional 1/8 - 1/4 turn to set the lifter preload.
Repeat this procedure on each of the remaining valves.
Turn off the engine.
Remove your oil splash apparatus and install the good valve cover.
Repeat these steps on the other side of the engine.
A mechanics stethoscope is handy to test for loose parts as the engine is running, you touch the stethoscope to the top of the rocker stud to hear if there are loose parts.
Oct 28, 2019 at 2:12 PM
