Valve cover torque specs?
2018 CHEVROLET CRUZE
100,000 MILES • 1.4L • 4 CYL • TURBO • 2WD • AUTOMATIC
CYRUAROEDDING
  • 10 POSTS
I have the next gen Cruze with aluminum valve cover. What are the torque specs for this model and sequence?
Also what is the torque for the vacuum pump?
Thanks
Sep 19, 2025 at 5:59 AM
Please start a new thread for the vacuum pump torque specs, the specs for the valve cover is:
15 nm or 11 lb ft.
Let us know if you need anything else.
Sep 19, 2025 at 8:31 AM
CYRUAROEDDING
  • 10 POSTS
Okay. Do you know the sequence for the valve cover bolts?
Sep 19, 2025 at 9:26 AM
Yep, here it is. Check out the images (below). Let us know how it goes.
Sep 19, 2025 at 10:27 AM
CYRUAROEDDING
  • 10 POSTS
Okay do you know the internals of this valve cover? A piece of the check valve or the only pcv valve that doesn't have a 5 point bolt it's push and click type fitting. We'll it broke when I was pulling the valve out and shattered into a few pieces and one piece fell into my valve cover potentially.
Just a 2mm by 7 mm part of the green clip that holds this valve in place.
Is it safe to run like this?
Will it stay in the baffling of the valve cover if it is in there.
I took the valve cover off and replaced the gaskets and the orifice valve and I tried blowing compressed air into the baffling but nothing came out of the valve cover so I figured it might not be in there
Sep 19, 2025 at 8:57 PM
Hmmm, that is difficult to say, anytime something foreign is inside the engine is not good, the plastic can work its way down into the oil pump pick up, I would try my best to find the piece. I might be stuck inside the baffle and be okay but I would not bet my engine on it.
Sep 20, 2025 at 7:14 PM
CYRUAROEDDING
  • 10 POSTS
How should I try getting it out I tried vacuuming and using compressed air
Sep 20, 2025 at 8:50 PM
CYRUAROEDDING
  • 10 POSTS
So should I take the valve cover off again and try harder to get it out? Would I need to buy a new set of gaskets? I only torqued the new ones and the engine hasn't run since its been torqued down.
Sep 21, 2025 at 6:52 AM
CYRUAROEDDING
  • 10 POSTS
If I can't find it should i just drop the oil pan in a month or so and see if it's there?
Sep 21, 2025 at 6:53 AM
Yep, that should do it. Let me know if you find it. :)
Sep 21, 2025 at 8:42 AM
CYRUAROEDDING
  • 10 POSTS
Thanks for the help.
Also, should I buy new gaskets or is the new ones I just put in good still. I haven't driven the car since replacing the valve cover gaskets but I torqued them down
Sep 21, 2025 at 9:19 AM
The gasket should be okay then.
Sep 21, 2025 at 9:23 AM
CYRUAROEDDING
  • 10 POSTS
Thanks man that was super helpful I took it apart again and vacuumed again and this time I got the piece out
Sep 21, 2025 at 3:01 PM
Nice work!! You are welcome, please use 2CarPros anytime we are here to help.
Sep 22, 2025 at 11:59 AM
