Vacuuming the AC
1973 FORD TORINO
85,000 MILES • 5.8L • V8 • RWD • AUTOMATIC
BENZESRULE
After vacuuming the AC system, I noticed after I close the valve on the gauges the system has a slow leak down. It is a very slow leak. What is the best way to find the leak? I plan on using R12 in this system.
Apr 20, 2017 at 4:09 PM
CARADIODOC
  • 34,306 POSTS
What is the history that led up to this? If this all started with a leak, and no pressure in the system, the standard procedure is to add some refrigerant, then use an electronic leak sniffer to search for the leak. Common locations are the crimp fittings on the ends of the rubber hoses, the seal behind the clutch on the compressor, the bottom of the condenser, and the evaporator. Find an evaporator leak by sniffing at the condensate drain tube in front of the firewall. Usually you will also see oil stains in the area of the leak, especially at the ends of hoses.
You can also inject some dye before charging the system. That takes longer to show up, but you find the leak by searching with a black light a day or two later. The dye will show up as a bright yellow stain that you can follow back to the source of the leak.
You could also still have some moisture in the system. The whole purpose of pumping the system into a vacuum is the extremely harmful moisture boils at 77 degrees in a vacuum, then it is easier to suck out. The way to identify if there is still moisture in the system is to let it sit for a few minutes under vacuum. If water is still vaporizing and expanding, you will see the vacuum being slowly lost on the low-side gauge, just like you described. That is why we need to know the history. If the car came in with no pressure, there is a leak that needs to be fixed. If the system had a charge but a part needed to be replaced, there likely was and is no leak, and you just need to pull a vacuum for a longer period of time. The industry standard used to be to maintain the vacuum for an hour, but most people have cut that back to a half hour.
Apr 20, 2017 at 4:28 PM
BENZESRULE
History of this car is when I bought it, the compressor, hoses, and condenser were missing. A friend gave me the A/C components off of his car. He said there was Freon in the systems but they have been removed along time ago. I replaced the drier on this system too. So this system has been empty for along time.
Apr 20, 2017 at 6:20 PM
CARADIODOC
  • 34,306 POSTS
Dandy. My main concern would be the evaporator. If it was not capped while the rest of the parts were missing, the humidity in the air flowing through it mixes with the oil in it to form hydrochloric acid, and that will corrode the metal. If I had to guess, I would say to start by pumping the system into a vacuum for a minimum of an hour, and near the end of that time, run the engine and bypass the low-pressure cutoff switch to force the compressor to run for just ten to fifteen seconds. That will whip up the oil in it and can release moisture that has become trapped in that oil.
Only do this with a motorized vacuum pump. The do-it-yourselfer compressed air units will not suck the system down to a perfect vacuum.
Apr 20, 2017 at 6:42 PM
