vacuum pod in drivers side fender
2003 CHEVROLET BLAZER
117,000 MILES • 4.3L • V6 • 4WD • AUTOMATIC
CARPETMAN1759
  • 81 POSTS
Vacuum pod is full of what looks like transmission fluid and is leaking out all over the vacuum hoses.
Aug 18, 2016 at 5:48 AM
HMAC300
  • 48,601 POSTS
check for a blocked PCV valve and system. transmission has no lines connected to engine unless it is a 350 or 400 three speed transmission.
Aug 18, 2016 at 6:16 AM
CARPETMAN1759
  • 81 POSTS
It s the stock 700R-4. It could be just oil but it does have a little tint of red in it. I pulled another one off a S-10 and it also had fluid in it. Also my four wheel drive pod under the battery tray has oil in it too. So I should check the PCV system?
Aug 18, 2016 at 10:43 AM
HMAC300
  • 48,601 POSTS
yes, it may be partially blocked and engine is putting oil in vacuum lines going to tanks. make sure PCV works well as well.
Aug 18, 2016 at 11:55 AM
