Which vacuum line needs to be removed to spray CRC GDI intake valve cleaner into for cleaning engine valve of carbon deposit?
2016 HYUNDAI SONATA
160,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
TRUONG VU
  • 14 POSTS
Hi, can you show me where the vacuum line that I should take off and spray CRC GDI intake valve cleaner into for cleaning engine valve of carbon deposit. A circled picture where it is located in the engine compartment is really helpful. Thanks
Apr 12, 2024 at 1:06 PM
I like to use the brake booster vacuum line, which is connected to the intake manifold, it is large enough to handle the cleaner. Check out the images (below). Let us know if you need anything else.
Apr 13, 2024 at 11:44 AM
TRUONG VU
  • 14 POSTS
Hi Ken, are there any sensors on the way to the engine that may be affected by the cleaner if I use this brake booster vacuum line to clean engine? Are there other vacuum lines that is easier to access that I can also use? Thank you so much for your help.
Apr 15, 2024 at 6:39 AM
You should be okay, but I have seen cleaners sometimes take out oxygen sensors but not all the time so be ready for that. I would use the brake booster hose, it works best.
Apr 15, 2024 at 9:31 AM
TRUONG VU
  • 14 POSTS
Thank you Ken. Really appreciate for your advice.
Apr 15, 2024 at 9:33 AM
You are welcome, let us know if you need anything else.
Apr 15, 2024 at 9:41 AM
