The brake booster and master cylinder were replaced (not sure if it was replaced with the original). After a month, we observed that the check engine light was on. The car was scanned, and the fault P0171 was found meaning system too lean bank 1. We found there is a vacuum leak between the master cylinder and brake booster. The master cylinder was removed, but there is no gasket or o-ring seal. Shouldn't there be one?
Apr 1, 2024 at 8:02 AM
