vacuum leak
1998 SATURN SW2
346,000 MILES • 1.9L • 4 CYL • 2WD • AUTOMATIC
UNCLEBIFF
  • 37 POSTS
It all started one morning, i went to work car was running fine. so i get to work shut it off and when i get in it to go home it started to have a rough idle, it was hard to keep it running at stop signs and low idles. It ran good on the freeway but when i got into town rough idle, had to keep it running. when taking off from a stop sign i would have to shift into second {automatic} to keep it from stuttering. on straightaways after it shifted into high gear i would have to put it back in second to keep it going. then finally one morning it actually shut off on the way to work, i let set for about twenty seconds or so it started back up shut off again after about one mile. made it to work after it would start but shut off when put in gear. had to tow it home. i replaced the plugs, wires, map sensor, coolant temperature sensor, transmission temperature sensor and IAC valve, still no change.
Mar 24, 2018 at 6:43 PM
Yes, is does sounds like you have a vacuum leak. can you follow this guide to see if you can locate the leak?
Do this with the engine cool. Also, check the air intake boot for tears.
https://www.2carpros.com/articles/replace-an-air-intake-boot
Mar 26, 2018 at 9:58 AM
UNCLEBIFF
  • 37 POSTS
So I found a break in the vacuum control signal tube replaced it -no change.but I noticed a lot of oil leakage on the lower end of the tube that where it connects to the purge solenoid (which has also got a lot of oil on it) the hose is pretty loosely connected could any of that be the culprit?
Mar 27, 2018 at 10:09 PM
It could be does the engine have excessive blow by? Remove the oil cap with the engine running let me know what happens?
Mar 28, 2018 at 3:27 PM
UNCLEBIFF
  • 37 POSTS
yes it has excessive blow by. i am about to start it up right now and remove the oil cap, i will get back to you.
Mar 28, 2018 at 5:33 PM
UNCLEBIFF
  • 37 POSTS
Okay, so i started it up and it sounded great idled strong, pulled off the oil cap some exhaust was coming out, but other than that, no change. then after it warmed up, it started sputtering was barely keeping itself alive, removed cap, no more exhaust, still no change. when i revved it up to around 2200 rpm's or so it ran fine but then eventually shut off at idle. flashed code po300.
Mar 28, 2018 at 9:02 PM
UNCLEBIFF
  • 37 POSTS
what were you looking for when i removed the oil cap?
Mar 28, 2018 at 9:03 PM
UNCLEBIFF
  • 37 POSTS
so i just performed a compression check; cylinder number. 1=135, number 2=0, number 3=0, number 4=140.
Mar 28, 2018 at 9:06 PM
Yep, nice work it looks like you may have a blown head gasket between two cylinders which is common.
Looks like we are removing the cylinder head. You will need to remove the front harmonic balancer.
https://www.2carpros.com/articles/how-a-harmonic-balancer-works
Here are the diagrams to show you the job you are in for (below).
Mar 29, 2018 at 1:50 PM
UNCLEBIFF
  • 37 POSTS
No way its just a cuppla stuck valves i suppose
Mar 29, 2018 at 5:58 PM
Could be but the head still needs to come off. Please take video or pics of the problem when you get it apart.
Mar 30, 2018 at 10:26 AM
