Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
Dodge
Ram
Engine
Symptoms
Vacuum Leak
IAC note sounds like vacuum leak
1997 DODGE RAM
262,000 MILES • 5.9L • V8 • 4WD • AUTOMATIC
KIMBERLEY72
MEMBER
1 POST
FOLLOW
Replaced crank sensor and IAC note sounds like vacuum leak. No codes no prior issue.
Dec 13, 2016 at 2:11 AM
HMAC300
CERTIFIED EXPERT
check for a vacuum leak like broken hose/off etc. also, check fuel pressure with a gauge auto parts rent it. check for duct work between air cleaner and engine for holes/ off. See link.
Dec 13, 2016 at 7:59 AM
STEVE W.
CERTIFIED EXPERT
Check over all the vacuum lines, especially the ones that run through the firewall, with that many miles you may have a cracked/broken line. Very easy to knock one off.
Dec 13, 2016 at 8:00 AM
