vacuum hose diagram?
2004 CHRYSLER PT CRUISER
99,679 MILES • 2.4L • 4 CYL
ANGEL DAVIS2
  • 4 POSTS
Had to change out turbo charger and forgot to label where these hoses went. can someone please help?
May 24, 2019 at 8:49 AM
SCGRANTURISMO
  • 4,897 POSTS
I have included the information that you requested in the diagrams down below. Please get back to us with what you are able to find out.
Thanks,
Alex
2CarPros
May 24, 2019 at 2:29 PM
ANGEL DAVIS2
  • 4 POSTS
Had to replace turbocharger and friend forgot where the lines go leading off turbo and Waste-gate. can someone please provide a video and/or pictures of all vacuum lines and tubes of where they are located? please
Jan 25, 2021 at 1:36 PM (Merged)
Welcome to 2CarPros.
Here are the directions for removal and replacement of the turbo. I am including all pics which relate to the procedure. They show all lines and hoses.
_______________________________________________________
TURBOCHARGER / EXHAUST MANIFOLD
REMOVAL
CAUTION: IF TURBOCHARGER IS REPLACED DUE TO A BEARING FAILURE, REPLACEMENT OF THE OIL PRESSURE FEED LINE IS REQUIRED. OIL RETURN TUBE SHOULD BE CLEANED ALSO.
NOTE: The turbocharger and exhaust manifold are serviced as an assembly. Do Not attempt to remove the turbocharger from the exhaust manifold. Exhaust leaks will result. It is recommended that the turbocharger elbow be replaced along with the turbochargerlexhaust manifold assembly.
1. Disconnect negative battery cable.
2. Drain cooling system.
3. Remove air cleaner housing and lid.
pic 1
4. Disconnect clean air hose from turbocharger (Fig. 21).
5. Disconnect throttle and speed control cables at throttle body.
6. Disconnect electrical connectors from the following components:
^ Inlet Air Temperature (IAT) Sensor
^ MAP Sensor
^ IAC Motor
^ Throttle Position Sensor
^ Ignition Coil Capacitor
^ Upstream Oxygen Sensor
pic 2
7. Disconnect air inlet hose at throttle body (Fig. 22).
8. Disconnect vacuum hoses at throttle body and upper intake manifold.
pic 3
9. Remove upper intake manifold support bracket (Fig. 23).
10. Remove upper intake manifold.
CAUTION: Cover lower intake manifold opening with suitable cover to prevent any foreign objects from entering.
pic 4
11. Remove turbocharger upper heat shield (Fig. 27).
pic 5
12. Disconnect oil supply line at turbocharger (Fig. 24).
13. Remove coolant return line (Fig. 24).
14. Disconnect vacuum hoses from turbocharger.
15. Raise vehicle on hoist.
16. Disconnect muffler ground strap. Remove muffler.
17. Disconnect downstream oxygen sensor.
pic 6
18. Remove fasteners securing catalytic converter to exhaust manifold (Fig. 25).
19. Remove catalytic converter and intermediate pipe as an assembly.
pic 7
20. Remove turbocharger to charge air cooler hose assembly (Fig. 26).
21. Remove turbocharger elbow support bracket (Fig. 27).
22. Remove turbocharger support bracket (Fig. 27).
23. Remove oil return tube (Fig. 24).
24. Remove turbocharger coolant supply line (Fig. 24).
25. Remove turbocharger lower heat shield (Fig. 27).
26. Remove turbocharger elbow (Fig. 27).
27. Remove lower exhaust manifold fasteners that are accessible while vehicle is on hoist.
28. Lower vehicle.
29. Remove upper exhaust manifold fasteners.
30. Remove turbocharger/exhaust manifold assembly from above/between the engine and cowl panel.
31. Remove and discard exhaust manifold gasket.
INSTALLATION
1. Clean gasket sealing surfaces. Replace exhaust manifold gasket. DO NOT APPLY SEALER TO GASKET.
NOTE: Stainless steel layer of exhaust manifold gasket goes against cylinder head, graphite layer of gasket goes against manifold surface.
2. Turbocharger/exhaust manifold assembly is installed from above/between the engine and cowl panel.
pic 8
3. Position turbocharger/exhaust manifold assembly in place. Gradually tighten fasteners, starting at center and progressing outward in both directions to 28 Nm (250 in. lbs.) (Fig. 28). Raise and lower vehicle for fastener access as necessary Repeat tightening procedure until all fasteners are at specified torque.
4. Install turbocharger elbow. Torque fasteners to 28 Nm (250 in. lbs.) (Fig. 27).
5. Install turbocharger lower heat shield. Torque fasteners to 28 Nm (250 in. lbs.) (Fig. 27).
6. Install turbocharger coolant supply line. Install NEW washers (Fig. 29). Torque banjo fitting bolt to 30 Nm (22 ft. lbs.). Torque flared fitting to 31 Nm (23 ft. lbs.) (Fig. 24).
7. Replace oil return tube gasket. Install oil return tube. Torque fasteners to 12 Nm (105 in. lbs.). Make sure heat shield for oil return line is properly installed (Fig. 24).
8. Install turbocharger support bracket. Torque M8 fasteners to 28 Nm (250 in. lbs.) and M10 fasteners to 54 Nm (40 ft. lbs.) (Fig. 27).
9. Install turbocharger elbow support bracket (Fig. 27).
10. Install turbocharger to charge air cooler hose assembly (Fig. 26).
11. Install catalytic converter and intermediate pipe as an assembly.
12. Install fasteners securing catalytic converter to exhaust manifold (Fig. 25). Torque fasteners to 28 Nm (250 in. lbs.).
13. Install muffler. Connect muffler ground strap.
14. Connect downstream oxygen sensor.
15. Lower vehicle.
16. Connect vacuum hoses to turbocharger.
pic 9
17. Install coolant return line. Install NEW washers (Fig. 29). Torque banjo fitting bolt to 30 Nm (22 ft. lbs.) (Fig. 24).
18. Connect oil supply line at turbocharger. Torque flared fitting to 31 Nm (23 ft. lbs.) (Fig. 24).
19. Install turbocharger upper heat shield. Torque fasteners to 28 Nm (250 in. lbs.) (Fig. 27).
20. Install upper intake manifold.
21. Install upper intake manifold sup port bracket (Fig. 23).
22. Connect vacuum hoses at throttle body and upper intake manifold.
23. Connect air inlet hose at throttle body (Fig. 22).
24. Connect electrical connectors to the following components:
^ MAP Sensor
^ IAC Motor
25. Connect throttle and speed control cables at throttle body
26. Connect clean air hose to turbocharger (Fig. 21).
27. Install air cleaner housing and lid.
28. Fill cooling system.
29. Change oil and filter.
30. Connect negative battery cable.
Please let me know if this helps or if you have other questions.
ANGEL DAVIS2
  • 4 POSTS
I am including some pictures can you please tell me where they are supposed to go.
Welcome back:
Honestly, without being there that is a tough one. Can you identify the ports in the pictures I attached?
ANGEL DAVIS2
  • 4 POSTS
The ports are coming off the turbo charger.
Welcome back:
Please understand, I don't know where those vacuum hoses are running. Take a look at the attached picture and let me know if it helps.
JAMES SAVOIE
  • 9 POSTS
Hello Joe, can you match up the lines to the ports on this picture to which relay they go to, and their tubing colors, I used Paint app to markup picture.
I installed it turned over engine with spark plug wires out until I achieved oil pressure to ensure turbo bearings had sufficient oil before starting engine. The turbo has high pitch noise while driving. I put a vacuum cap on unknown port seemed to increase performance 90KM driven since installing, no tech support from Rock Auto and no Contact info for Ultra-Power Tech support.
Aug 9, 2022 at 3:58 PM
How have things turned out with your plan?
Interested in knowing.
Aug 11, 2022 at 7:10 PM
