Happy to hear you solved it. To address the comment about the amount of refrigerant. I too would leave it alone. At the exact proper charge, the lower half of the evaporator in the dash will have liquid and the upper half will be vapor. The point at which it turns from liquid to vapor is where it gets real cold. With too much refrigerant, the evaporator will be overfull with liquid, then it changes state too close to the pipe leading back out to the compressor. The "cold" will be developed under the hood instead of in the heater box. With even more overcharge, liquid can slosh into the compressor and destroy the valves or at least lock it up.
With too little refrigerant, as you may have now, the liquid level in the evaporator will be too low, but as long as there is some liquid, that is still where it's going to get cold. At worst, due to normal leakage over time, you might lose cooling efficiency in, lets say five years instead of six. As long as it's working fine now, there's little point in starting a new can.
Be aware too, if you pop a cooking thermometer in one of the vents, the lowest temperature you should see is around 40 degrees F. The goal of AC systems is to lower the air temperature only 20 degrees. The comfort comes from removing the humidity. And let's face it; 40 degrees is not comfortable. Systems are regulated, either with a pressure sensor, or a temperature sensor to go no lower than 40 degrees. The reason is that humidity condenses on the evaporator, then drips into a pan, then out onto the ground. If the evaporator gets to 32 degrees, that water freezes into ice that blocks air flow. Temperature sensors are usually placed right in the middle of the evaporator, but if there's too much refrigerant, the coldest area of the evaporator will be higher than the sensor. Some freeze-up can still occur.
Jul 2, 2025 at 7:35 PM
