I have a 350 turbo engine, GM 11" manual disc brakes in front, Ford 9"with 15/16 wheel cylinders in rear. What master will work? I have a 1 1/8 power brake master cylinder on car now and have zero brake pressure and zero pressure in system. I was told never use a master cylinder bigger than a 1" bore for manual disc. Is that true? The car had a "shallow bore piston from the factory with a 7/8 bore. I could bleed and get pressure but still had no brakes, pedal always went to floor. I am looking at ACdelco master cylinder number 18m1988 and/or Raybestos master cylinder MC 36233. Can either of these be used? Is there such a thing as "manual disc brakes" ever used on a GM car? When and what car? What part number and maker of master cylinder? Thanks.
Jul 20, 2018 at 9:53 AM
