First we did the flywheel, clutch-plate and throw-out bearing, it seemed we had solved our car problem. Then about tow weeks later it stopped shifting into gear while car is on. Goes into all gears in neutral. So tore down again, (saturn sl1 clutch work is tremendously mind blowing excessive BS).
Checked flywheel clutch-plate throw-out bearing, cleaned and put it all back together again. Darn! not fixed. So replace complete clutch master cylinder (sealed system). It now has a stiffness in pedal, like something is "binding" up in there. I have watched whatever YouTube tutorials trying to find the answer. It appears it is always the same answers. Tried pedal adjustments, etc.
My question is this, should the clutch "fork" be able to be engaged/disengaged by simply using my fingers to move it?
One more, what ever else could it be? A new car? wink wink, not today. Anyways any help with the new parts i have would be much appreciated like ASAP!
Makes noise when pedal is.
Nov 13, 2016 at 8:22 AM
