upstream oxygen sensor removal for replacement?
2019 CHEVROLET MALIBU HYBRID
38,500 MILES
HBNOREEN
  • 5 POSTS
I am trying to replace an upstream oxygen sensor on the vehicle listed above; GM part 55485043, but I am having a problem removing the old part. I can't get the wire connector off. What's the trick to disconnecting, please?
Feb 12, 2023 at 12:32 PM
Do me a favor. Take a look at the pic I attached below. I circled a spot on the connector where I believe there is a plastic retainer/lock. It could be any color but usually, it will be red. If it is there, carefully slide it out. Once it is out, you will be able to depress the release and disconnect the connector.
Let me know if this helps.
See pic below.
Feb 12, 2023 at 8:41 PM
HBNOREEN
  • 5 POSTS
Yes, it's a white clip and I've pulled it up but still can't pull the 2 apart. Is there any other clip? What did you mean by depress the release? Thank you.
Feb 14, 2023 at 7:20 PM
Make sure the clip is far enough out. It is in there to prevent the release from depressing. There should be a tab that will depress and allow the two to come apart.
If you are questioning the retainer, remove it completely. There could be enough still engaged preventing you from depressing the tab.
If you still have a problem, take a pic of the connector (as best as you can) from a couple of different angles and upload the pics for me to see. Maybe it is something different than what I have seen.
Feb 15, 2023 at 6:18 PM
HBNOREEN
  • 5 POSTS
Thank you Joe.
You have the correct piece. It's stubborn.
Appreciate your patience and assistance.
Feb 17, 2023 at 5:27 PM
No problem whatsoever.
I copied one of your pictures. I circled the white clip in black. That needs to be removed by sliding it in the direction of the arrow. The lower portion of that clip is preventing the release of the connector.
Once that is removed, depress the lever I circled in red. While depressing it, wiggle the connector a bit and pull it apart.
See pic below.
Feb 17, 2023 at 8:53 PM
HBNOREEN
  • 5 POSTS
OMG finally. Pull the white clip up and squeeze so that black part behind pushes in and pull two connectors apart at same time. I broke the fastener that holds it in place when I was first wriggling it to get the connectors apart. Do you know part number for fastener please?
Feb 18, 2023 at 2:31 PM
Glad you got it apart. I'm not sure if you can even purchase a new retainer without the connector.
I did find this site. Check it out and contact them to see if they have what is needed. Also, if you still have the broken one, see if a parts store has one.
https://www.te.com/usa-en/product-967634-1.html
I believe the color of the retainer is related to the size. (If that helps).
Let me know what you find.
Feb 18, 2023 at 6:01 PM
HBNOREEN
  • 5 POSTS
Thanks so much. I used a zip tie to hold it in place. The replacement was so easy once I got the connections apart. Really appreciate your kind assistance.
Feb 19, 2023 at 9:14 AM
That will work. LOL You are very welcome. I'm glad to know I helped, and you got it done.
Take care and feel free to come back anytime in the future.
Feb 19, 2023 at 10:23 PM
