Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
BMW
745
Engine
Timing Chain
Cover
upper timing chain gasket
2002 BMW 745
208,996 MILES • 4.4L • V8 • RWD • AUTOMATIC
REARDRIVE
MEMBER
FOLLOW
I have a short question; can you put the upper timing chain gasket on without removing valve cover if so how?
May 25, 2016 at 11:02 AM
DOCHAGERTY
CERTIFIED EXPERT
No, you cannot do that. The valve cover comes off before that can be performed
May 25, 2016 at 5:37 PM
CERTIFIED EXPERT
Thanks Dr. nice to see you on, cool cat! :)
May 25, 2016 at 5:55 PM
REARDRIVE
MEMBER
I just put new valve cover gasket on do I need to buy another set of valve cover gasket ? Thank you
May 26, 2016 at 12:44 AM
MHPAUTOS
CERTIFIED EXPERT
If it is a rubberized gasket and not glued you should be able to re use it after such a short time,, otherwise replace it to be safe.
May 26, 2016 at 3:38 AM
REARDRIVE
MEMBER
THANK YOU
May 26, 2016 at 4:10 AM
DOCHAGERTY
CERTIFIED EXPERT
Agreed Thx Mark
May 26, 2016 at 3:33 PM
