shock?
2006 CHRYSLER SEBRING
154,000 MILES • 2.7L • 6 CYL • FWD • AUTOMATIC
CMZANNN
  • 84 POSTS
When applying brakes right before completing stop car felt like a transmission slippage at stop. after checking transmission fluid not burnt adding Lucas stop slip. oh yeah I was hearing what seemed like something was loose on front passenger area. not hearing that anymore. today I actually opened hood passenger side shock is not in centered. leaning towards engine I was ale to pull by hand some. the transmission like stopped. car does not pull to one side or other tracks straight.
as always I came to the best place on the web for the correct answer. thanking you in advance for your invaluable help.
Jul 26, 2017 at 11:10 PM
HMAC300
  • 48,601 POSTS
have a mechanic check this for a worn bushing they normally do this on an alignment. so if top plate was moved it may look off center as well. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
Jul 27, 2017 at 6:53 AM
