Within 5 minutes of driving, exhaust manifold and collector gets red hot (causing a fire one time). I checked EGR valve which is not clogged. Number three cylinder has low compression (30PSI). Excessive pressure in valve cover. Replaced PCV valve, spark plugs. Oil leaks into the air box. Exhaust doesn't seem to be clogged. Gets really hot by the O2 sensor closest to exhaust manifold. Could be head gasket but does not exchange fluids oil/coolant. Stumped
Jan 30, 2022 at 4:16 PM
