Hi everyone,
I’m writing from Uruguay. I recently installed a pair of Old Man Emu Nitrocharger Plus front struts (Part No. 93032) on my 2024 Nissan NP300 / Navara D23, using stock upper mounts and coil springs.
After installation, I noticed a clunking noise coming from the front suspension under certain conditions:
• Hard braking at low speeds, especially on a downhill slope
• When going over speed bumps
• When rocking the car laterally (by pushing on the roof)
Interestingly, the noise is not present while driving at high speeds, and it has gradually reduced over time. The vehicle handles very well on the highway (even at 160 km/h), but the knocking is noticeable at low-speed suspension compression or rebound.
I suspect this may be related to:
• Preload setting on the strut spring seat (I used the 10 mm clip setting)
• Bushing preload on the lower shock mount, possibly torqued with the suspension unloaded
So, my questions are:
1. Has anyone experienced similar noises with OME Nitrocharger struts?
2. Could this be due to excess preload on the spring seat or incorrect torque on the lower shock mount bushings?
3. Does anyone have the official torque specs for:
• Top strut mount (3 bolts)
• Lower strut mount bolt (to lower control arm)
• Sway bar link
• Upper ball joint (if relevant)
Unfortunately, in Uruguay we don’t have local ARB suspension specialists, so any help or shared experience would be extremely appreciated.
Thanks in advance!
—Juan Pablo
• Sway bar link
Thanks in advance!
—Juan Pablo
Aug 8, 2025 at 4:40 AM
