Up sizing tires on my
2016 CHEVROLET SUBURBAN
34,000 MILES • V8 • 4WD • AUTOMATIC
BRAD STEINFELD
My SUV is the LT model. It is due for new tires and I would really like to gain a bit of height by going with a set of 275/60r20's instead of the 275/55r20's that are the stock size. It appears that there is plenty of room in the wheel wells. I understand the change will effect my speedometer accuracy by about two mph. Are there any other issues serious enough to not go with the size change? Thanks.
Mar 7, 2017 at 12:51 PM
MHPAUTOS
  • 31,937 POSTS
there should be no real problems with this tire selection. the different aspect ratio is only minor a long as all four tires are the same there should not be a problem.
Mar 8, 2017 at 3:58 AM
BRAD STEINFELD
thank you !
Mar 8, 2017 at 4:46 AM
MHPAUTOS
  • 31,937 POSTS
no worries, thank you for using 2carpros, see you again some time........
Mar 8, 2017 at 11:44 PM
