Unusual clunking sound
2000 FORD KA
71,000 MILES
AMBERVC
This car has seen better days. A new problem has arose today and I could do with a diagnosis and an estimation of how much it would cost to fix.
I have been driving it for 3 months and when I got the car, I was told that the clutch had just been replaced. I have had trouble with gears grinding since the beginning (1 in every 3 journeys roughly) and I find that for me to go from 3rd to 2nd the clutch has to be in a certain position, also the same for the reverse gear otherwise it won't have it. More recently for the past week I have had difficulty with getting from 2nd to 3rd.
Today I was going round a roundabout, trying to get into 3rd, gear grinding. Stop at the traffic lights. A repeated clunk now occurs every 5/6 seconds whether the clutch is depressed or not. Also when it is idle and in 2nd gear. I don't know about 3rd or higher as the sound and vibration of the engine masks it. But I can only feel the clunk through my foot being on the clutch pedal. It doesn't seem to get any faster when going quicker either.
Sorry to be so thorough with my description but no other forums seem to be matching my "symptoms". Hope someone can help and thanks for taking the time to read!
May 1, 2013 at 5:29 AM
HMAC300
  • 48,601 POSTS
try shifting gears engine offand car stopped . if it shifts ok there it may be a clutch problem check your adjustment, and fluid in trans eleimnate all the small things. It sounds like you may have a synchro problem in trans and maybe a worn clutch though. we have no info on these cars.as we dont' have them in u.s. The clunk I would have to think is a clutch problem as you only feel it there or maybe a pilot bearing in end of crank letting input shaft of trans move more than it should. This sounds like something yo won't really know until it comes apart.
May 1, 2013 at 6:41 AM
