Do you have a little history on this van? Have you owned it since new? If not, do you know if it was used as a business vehicle prior to you owning it?
The reason I ask is, this does not appear to be a factory harness. The loose wires that are hanging off it is not done by the factory because they don't build a vehicle with extra wiring like this. Also, the lack of friction tape or wrapping for the harness is not factory. Basically, they wrap the harness in black tape or other protective coverings to protect it from rub through.
What I suspect this is, was an addition to the van by a previous owner for a tracking device or other module that was needed for their business.
Let me know if this history matches up with my suspicions.
Aug 29, 2019 at 6:07 PM
