I had a broken tire belt, and it was really bad. It was thumping and jerking bad. I replaced the tires. After i started hearing this rotational type of kind of thud sound, it gets faster with speed and sounds like a rotational thud or rubbing when I turn left its more noticeable than when turning right but is constant even when driving straight. I thought it was bad bearings so replaced them and still doing the same thing. Control arms have been replaced and the entire suspension has been checked three times and everything is fine. Motor mounts were also replaced and still no change. I was told maybe a really bad alignment but my car steers just fine. I mean the alignment is a tad bit off but i don't think it's causing the noise, it's not that bad at all, like you can't even really tell its off. Does anyone have any ideas on what is causing the noise? I have had 2 different certified mechanics look over everything and they are stumped.
Feb 28, 2022 at 8:49 AM
